Anyone know what this code is. I can read it on my edge but I don't know what it means. My f150 throws this code mainly when it's warmed up and in stop and go traffic or after I am on the freeway for a while and come to a stop and then proceed. I don't know if this is only when the code comes but when I notice it.
the code is for a throttle body leak or low air flow ...so if you have a aftermarket intake it could be leaking or you might need to clean you throttle body it self
I cleaned the throttle body, I cleaned out the intake. I thought maybe I was getting some leak out of the intake to so I sealed all moving points of connection from the intake to where it goes out the side of the inner hood area. I'm still getting the code, and, in the same places and times.
No broken wires- I did look. No, not dirty. I did look at the electriacal connections around the intake and made sure all was connected and looked right. The code doesn't come up continually. I can drive for a couple hours and nothing happens, then it can happen. Or if I don't drive much I won't see it for a while-it always comes back though.
