blinking seat belt indicator????
Old Nov 29, 2008 | 08:13 PM
roadrunner doug's Avatar
roadrunner doug
My 95 f-150 is flashing my seat belt indicator at me.3 times,then 1 time ,then 3 times.Is this some kind of code??????Thanks
Old Nov 30, 2008 | 07:27 AM
EPNCSU2006's Avatar
EPNCSU2006
Could it be the airbag light instead? Do your horn and cruise control still work properly?
Old Nov 30, 2008 | 07:47 AM
roadrunner doug
My be ,I thought I used the horn yesterday,I will check today.I thought it was seat belt light.I get back to you about 10.00 today.
Old Nov 30, 2008 | 09:42 AM
jonwoos's Avatar
jonwoos
If you got cruise check it too. The cruise, air bag, and horn all go thru the clock spring behind the steering wheel itself. It is probably bad, if I remember right mine flashed 31.
Old Nov 30, 2008 | 10:10 AM
roadrunner doug
There is a clicking noise in my stearing wheel .
Old Nov 30, 2008 | 10:12 AM
roadrunner doug
There is a clicking sound all of a sudden in my wheel.What does the clock spring do???
Old Nov 30, 2008 | 10:18 AM
jonwoos's Avatar
jonwoos
It is really brushes for electrical connections from the horn, air bag, and cruise wiring down into the column wiring. It allows for rotation of the steering wheel.
If you hear clicking it is probably bad.
Old Nov 30, 2008 | 10:23 AM
roadrunner doug
Thanks,my buddy put an ignition switch in about the last time I drove it.He probibly messed it up.
Old Nov 30, 2008 | 10:26 AM
jonwoos's Avatar
jonwoos
Or, left it unplugged.
