Sponsored by: Real Truck
outside air temp screwed up
Old Nov 29, 2008 | 01:39 PM
motor12's Avatar
motor12
i have a 2008 F250. the outside air temp only changes three to five degrees and is usually way off.is it the sensor or something else. will a new sensor correct the problem. thanks
Old Nov 29, 2008 | 01:42 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Do you have a snow plow or factory winter front (grill cover) on the truck? Both have been known to cause problems with the air temp sensor...
Old Nov 29, 2008 | 02:03 PM
motor12's Avatar
motor12
nothing in front of vehicle, plow,ect. stock grill
Old Nov 29, 2008 | 02:23 PM
riggz's Avatar
riggz
Take it back to the dealer and have it fixed under warranty?
Old Nov 29, 2008 | 02:45 PM
Green Ford's Avatar
Green Ford
It's located in the lower right side of the grill. I noticed mine was way off a while ago after some work. Found out it had poped out and fallen down. poped it back in and it's dead on.
Old Nov 29, 2008 | 04:11 PM
motometal04F350's Avatar
motometal04F350
i am having the same prob. usually its about 5-6 degrees colder than ooutside ambient air temp....
Old Nov 29, 2008 | 06:09 PM
senix's Avatar
senix
i would take it in under warrenty
