WARN hub loose?
Old Nov 29, 2008 | 11:08 AM
puck1263's Avatar
puck1263
WARN hub loose?
Hi all.
I've got a 90 F150 4x4 with manual locking WARN hubs. Just recently I've noticed on my passenger side a grease stain around my hubs. It is the whole circumference of the hub, about 1/2" wide. The silver outside portion of the hub is a bit loose if I wiggle it. The allen nuts that hold it on are tight. 4x4 still works to my knowledge, but I'm worried about damage. Should I get this checked out?
Old Nov 29, 2008 | 03:53 PM
cjg1999's Avatar
cjg1999
sounds like you need a gasket. they are supposed to have one, I am missing one on my 94 w/ warn hubs. same thing as you, grease on the hub lock.
Old Nov 29, 2008 | 05:00 PM
puck1263's Avatar
puck1263
Should I have it looked at right away?
Old Nov 29, 2008 | 05:04 PM
andy22285's Avatar
andy22285
the aftermarket manual hubs don't stay completely tight, as they are only held in by a snap ring, this is normal. as far as the grease leaking out you may need a new gasket, it looks like a rubber band and fits inbetween the cap and the lock itself.
Old Nov 29, 2008 | 05:30 PM
puck1263's Avatar
puck1263
How do you replace the gaskets?
Old Nov 30, 2008 | 02:24 AM
White Max's Avatar
White Max
Remove the cap bolts, then pull the cap out. The o-ring gasket that needs to be replaced will be right on the cap. It's a ten minute job at the most.
-Rod
Old Nov 30, 2008 | 05:47 AM
puck1263's Avatar
puck1263
sweet. I was hoping that is what you'd say. I'll get er done. Thanks guys.
Old Nov 30, 2008 | 05:48 AM
puck1263's Avatar
puck1263
oh yeah, one more thing.
With the gasket leaking, should I be concerned about repacking the bearings? There doesn't seem to be a lot leaking, but enough for the smear.
Mac J
Nov 23, 2016 09:40 AM
Fastback460
Nov 29, 2014 05:13 AM
eldorado73
Jan 21, 2012 08:16 PM
fergman76
Feb 15, 2009 06:54 PM
Nightrain
Offroad & 4x4
Oct 10, 2006 10:53 PM
