4x4 problem
Old Nov 29, 2008 | 09:16 AM
cbinkcak's Avatar
cbinkcak
4x4 problem
Hello,I put manual hub on a 1997 ranger last year.
Now it will not go into 4 wheel drive(hi or lo).The lights on the dash light up when it is started,they work when you turn the switch from 2 wheel drive to 4 hi and lo,but the eletric shift motor doesn't turn.
The fuses are all good,even the ones under the hood.
I installed a new electric shift motor,but it doesn't do anything either.There was a wire from the transfer case to the old shift motor.I stripped the wire on the plug going up thru the floor (black I think)and connected them together, and still nothing.
What else can I try now?
Thanks.
