Exhaust Manifold Question
Old Nov 28, 2008 | 11:36 PM
Steel357's Avatar
Steel357
Hi guys
I just got my 60 F350 with an 223 Inline to idle properly but when its idling there is alot of whitish smoke that is coming out of the tailpipe and it leaks from out of the manifold. (It was NOT thick and billowy) I'm pretty sure that I need new manifold gaskets. But does this color and amount of smoke mean that my mixture is too thick?
Old Nov 28, 2008 | 11:51 PM
Julies Cool F1's Avatar
Julies Cool F1
Hi Steel357,
Hmmmm, well no, if you are running too rich fuel wise, your smoke would be black. If it's gray that usually means you are burning oil. If it's white (not light gray but white) that probably means you have a coolant leak that you are flashing into steam. Does the "smoke" hang around, or does it seem to vanish?
Try it on a really cold morning and see if it acts more like steam than smoke. If it "vanishes" then it's steam and you've got some coolant leak problems. You will be able to smell the coolant if that's what it is as well.
Julie!
Old Nov 28, 2008 | 11:57 PM
Steel357's Avatar
Steel357
Thanks!
The smoke seemed to hang around. I dont think it was a coolant leak cause I couldn't smell any coolant and it was a pretty cold day today when i was idling it and the smoke just hung around under the hood.
Old Nov 29, 2008 | 01:03 AM
Julies Cool F1
Originally Posted by Steel357
Thanks!
You are probably burning oil then. That could be a few things. But if it's coming out the tail pipe too, then it's internal and not just an oil leak dripping on the manifold. I'd just drive it. But just in case, check your oil dipstick once every couple of drives and check for milky white sediment in it.
J!
Old Nov 29, 2008 | 06:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old used car dealers trick:
With the engine running, put your hand a few inches from the tailpipe.
If moisture appears on your hand = it's prolly a blown head gasket.
Old Nov 29, 2008 | 09:05 PM
Steel357's Avatar
Steel357
hey thanks alot guys, I think it was just burning oil, i changed the oil and it stopped
