rear diff fluid recommendations
Old Dec 2, 2008 | 10:58 AM
starmilt's Avatar
starmilt
Yea I would I would think it would be pretty cheap and easy ti remove the cover and weld a pipe bung in it.
If you do weld a nut on your plug be sure to ground it close to your weld not where currant will travel through your bearings.
Old Jan 11, 2009 | 03:10 PM
Glockem45's Avatar
Glockem45
Question
Could we get this post back on track.
So what brand and type (i.e. weight) of rear diff oil should we be using? My truck is below.
Old Jan 14, 2009 | 06:24 AM
DeepRoots's Avatar
DeepRoots
leave the plug alone.
drain via taking the cover off.
fill via the vent.
I fill this way anyhow so I can sit instead of lay
