how loud
Old Nov 28, 2008 | 07:49 AM
cpettymore7777's Avatar
cpettymore7777
Post how loud
how loud would my 351 be if i run straight pipe from the cat? the cat is stock and huge and i wanted to make it louder and was wondering if i have to replace the cat too.
Old Nov 28, 2008 | 08:22 AM
Conanski's Avatar
Conanski
If the cat is all stock it won't be very loud at all, see for yourself, drop everything behind the cat and go for a drive.
Old Nov 28, 2008 | 08:51 AM
jr32560's Avatar
jr32560
yeah your right on that Paul all I got is a converter and no pipe after that -still kinda quiet-well it's a 302-
Old Nov 28, 2008 | 10:07 AM
Suburban_B_Gone's Avatar
Suburban_B_Gone
I have a 4.9L I6 with straight pipe behind the OEM catalytic converters exiting in the factory location; not too loud at all. It even seems to last longer up here in the salt ridden rust belt. I am very satisfied with this setup, and will probably never replace the muffler.
Hope that helps,
-JR
Old Nov 28, 2008 | 10:34 AM
stanger_missle's Avatar
stanger_missle
Yes, it won't be as loud as you were hoping. I have owned 2 351W powered trucks; a 1990 E150 van and a 1995 F150. Both had the exhaust cut off right after the second cat. You would never guess that that there was no muffler.
My F150 has a 18" section of flex pipe that points out the passenger side right after the cab. Its still very quiet. I contemplated putting an old Flowmaster muffler on that I have sitting in my garage, but it doesn't change the sound at all.
Just my .02
Old Nov 28, 2008 | 11:01 AM
jadmt's Avatar
jadmt
I have a 460 and when I went with a 3 inch cat back muffler I had them try running a 3 inch pipe right off the stock cat. and it was too friggun loud for me. I know a 460 is probably putting out more sound then a 351, but it is easy to try to see for yourself.
Old Nov 28, 2008 | 12:07 PM
Fordenthusiasts's Avatar
Fordenthusiasts
I have a 302 and when I got it, it had dual pipes after the two cats with no muffler and you could hardly hear the thing. I took off the second cat, which was the bigger one and put 3.5x20 inch tips on and it made quite a bit of difference. It has a real nice deep gurgle to it, but I am a teenager and am looking for more noise so sometime I am going to take off the other cat and run straight pipes, but I don't have emission testing so I don't have to worry about having a cat, which you might have to depending on where you live.
