CB's
If it was me I would attach a ground strap to the trunk (the photo you provided and attach it to the body of the vehicle plus,scrape a small amount of paint to allow the set attachment screw a good ground.
You have what is called a "Base Load" antenna.
The base should be mounted as high as possible on the vehicle.
A base load on a truck should be in the form of a magnetic mount for the ROOF.
Attaching a base load antenna so that the cab interferes with the signal is lowering performance.
Rules of Best performance:
1)Proper Match Antenna to radio(swr)
2)Proper and secure grounding of Radio & Antenna.(find un-painted metal)
3)The *LOAD* of the Antenna should be as High as possible on the Ground Plane. ie: roof mount
4)Know about your system > The Most powerful strength signal goes out the longest part of ground plane; ie: rear mounted antenna> The best signal goes out the Front of the vehicle(ground plane)<>antenna on the front of vehicle > the best signal goes out the rear of the Vehicle.
Center mounted antenna> The signal goes out the front and rear of vehicle equally
The signal out both sides is equal to each other.
I hope this clears up your question.
Dual-antennas are slightly different in performance.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Mike S.
1979 F-100
Although it's been awhile, there used to be a real good CB shop at the Shell truckstop in Holbrook, AZ, and another one at Sapp Bros. truckstop (Exit 1) in Council Bluffs, Ia. I was just in Sapp Bros about a month ago.
Trail Rider
My term was "Push and Pull" >Bi-Linear amplifier<
w/Explorer Pkge.
84 Volvo DL Wagon
E-Mail me direct.
w/Explorer Pkge.
84 Volvo DL Wagon
Why would you want a piece of equipment you can't transmit over?
Trail Rider
It's legal for that reason.
I used to say " It's For the Convincing Break"
We have mountains in close proximity to Calgary.
In 5 years I had participated in at leats 7 search & rescue incidents for lost children,accident victims,lost animals,rescue of snowmobilers.
I have a 200 Watt Push & 400 watt pull Bi-Linear amplifier just for this reason.
That's why I have one.
To *Get out* and *Pull Them In*.
w/Explorer Pkge.
84 Volvo DL Wagon
>favorite radio is a 23 channel Browning "Brownie". I use it
>when I'm on the road mated to a 5' Firestik. When I bought
>my wife her '94 F150 I needed a small radio cause there was
>really no place to mount one. I ended up buying a factory
>reconditioned unit from a radio shop, and part of the guy's
>service was to turn up any radio he sold. It puts out about
>18 watts, the only problem is the mic's on these radios is
>junk from the factory, the good thing about them is a 4 pin
>Cobra/Uniden mic fits and works perfectly. It's a Uniden Pro
>510 XL (I don't care for all the extra ***** and switches).
>Since then it's been moved to her car (95 Eagle Vision) and
>mated to a K40 whip. Since that first Pro 510, I've acquired
>two more, one of which is in my '93 Ford F250 mated to a 3'
>K40 whip, and the other is my "spare" when I'm on the road.
>My '72 F100 has a Cobra 21 GTL that has also been "tuned
>up".
> I agree with being irritated with all the noise and bs on
>the radio, and I know alot of folks shut their radios off
>(even truckers), but I also like to know as much as possible
>about what's going on out on the road when I'm out there. I
>guess I'm just a die hard when it comes to running a radio.
> You probably can't figure out my handle either (ha ha)
>They call me Trail Rider when they ain't mad at me - I'm
>headed for Mama's house. Bye Bye!
I have a Galaxy 55 (cliped and peaked) With a Texas Star H.D Box ,with an external speaker. I have a D104 power mic. and Wilson 5000 Antenner Handle >Diesel
you'll never avoid traffic.
Please Don't Ask Me Any Tough Questions,
78 F-150 429CJ,Silver, Explorer Pkg.
84 Volvo DL Wagon
