lights pulsate
Old Nov 30, 2008 | 03:32 AM
fmc400's Avatar
fmc400
MSEE
Thanks for the compliments Tees, glad I could help
Old Nov 30, 2008 | 01:08 PM
78Ranger_GARedNeck's Avatar
78Ranger_GARedNeck
Ha.. my headlights pulse in my truck..but thats because of the sub behind the seat...lol
but really, ive not noticed my truck doing that but my mom has got a 67' Stang w/ a 289. It is really bad about pulsing headlights, specially at idle. And they get brighter with more RPMs. Yes is has the modern stock alternator as apposed to a generator(like the 65's or 64 1/2's) so i dont guess its supposed to do that.
Old Nov 30, 2008 | 11:26 PM
Don S.'s Avatar
Don S.
If every thing is in good electrical conditions, clean tight grounds and posistive battery cables and reg and alt are good. It may be that the pull that came on the alternator your using has too big of a pulley on it.
For example if you had a alternator on a car that idles around 850 RPM and you throw it on a car that idles aroud 650 or 700 RPM that may be causing it to pulsate. As the rpm lower the alternator current output capacity drops.
Like my 200A alternator on my VW has a smaller pully on it so at idle Around 800 RPM iit will produce a maximum of 110 Amps @ Idle. Just something to keep in mind.
ncheavymetal
North Carolina Chapter
487
Mar 9, 2016 10:30 PM
mattymax
Dec 5, 2015 10:47 PM
ncheavymetal
456
Mar 20, 2015 07:31 PM
