Suspension!?!
Old Nov 27, 2008 | 09:51 AM
83F350351w's Avatar
83F350351w
Suspension!?!
hey guys, i have a 1983 F350 1ton with a rebuilt 351w and before i built it, the truck sat for about 12 years inside. It has IFS dana 50 with 2 leaf springs. If the truck sits over the years, does the suspension get sacked out and i only have 1 inch from my rubber bumper on the frame to the axle. should there be more than that!?
Old Nov 27, 2008 | 10:16 AM
uncle.stosh's Avatar
uncle.stosh
That's pretty common for all TTB Fords and has nothing to do with it sitting for so long.
Factory arch is about straight or a slight negative arch and not a good design.
Old Nov 27, 2008 | 11:32 PM
Franklin2's Avatar
Franklin2
The biggest problem is not the springs but the shackle bushings, especially the ones up inside the frame in the front. The TTB puts a twist on these bushings as it works up and down, and they do not last very long. If these are shot, replacing them will give you more room to the rubber bumper.
