Running Rough
Old Nov 26, 2008 | 10:47 AM
bnuvp's Avatar
bnuvp
Running Rough
2000 V10, 4x4. Running rough.
Had the shop that does my monthly(seems monthly) suspension repairs check for any codes, they said there were none. Check engine light isn't on.
Does the 2000 V10 provide codes for cylinder missing, lean mixture ect.?
Maybe they used the wrong scanner? (Not an engine shop.)
If feels like a cylinder is missing. No loud noise or tapping, so I don't think its a plug backing out or spit out, but I haven't checked yet.
It has sat for a couple of weeks do to gas prices, but with them down I can afford to drive it again but it's running like crap.
Does this year use the COP?
Is there an inexpensive scanner I can purchase?
Can you point me in the right direction?
Where is the engine on this thing???????
Old Nov 26, 2008 | 01:49 PM
Monsta's Avatar
Monsta
Sit. Stay.
Usually a bad COP won't throw a code until it is VERY bad.
When does it run rough? All the time? Just under load? At a particular RPM/throttle setting?
Always rule out the simple stuff first and use something to treat the fuel to ensure the fueling system is clean. I like Seafoam or Techron.
Check for vacuum leaks, check your air filter (Saw one that a mouse had camped in for a while: MESS!).
Alas, buy a COP and play round robin with it until the miss is gone.
Old Nov 26, 2008 | 02:43 PM
bnuvp's Avatar
bnuvp
Seems to idle fine.
In 3rd or OD at 1500rpm under it really shakes.
Take the foot off its fine.
Get over 2000, its okay, but no real power.
Old Nov 26, 2008 | 02:48 PM
bnuvp's Avatar
bnuvp
I started some injector cleaner this weekend.
No change yet.
Air cleaner is good.
Not sure how to check for vacuum leaks.
Old Nov 26, 2008 | 04:15 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Does the miss get worse as you accelerate? If i it does, it may be a coil because coils are stressed more under a load.
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
See your FTE special at:
https://www.ford-trucks.com/forums/793806-cop-fte-special.html#post6780133
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Nov 26, 2008 | 05:39 PM
bnuvp's Avatar
bnuvp
It does seem to be worse under power.
Unless I got the RPM's way up it really shakes.
It doesn't have the power it should have.
Old Nov 26, 2008 | 08:40 PM
Cardiac69's Avatar
Cardiac69
Bob, if it's misfiring that bad, it should have a code stored. If it is a COP, then it would show up as a P030x, where the "x" is the cylinder number of the misfire. Run it by Autozone and they will plug in their scanner at no charge.
Old Nov 28, 2008 | 09:18 AM
bnuvp's Avatar
bnuvp
Went to Autozone, scanner said cylinders 2 & 7 misfiring.
I'm going to change the plugs first.
How do you get to the back plugs?
How do you get a torque wrench back there?
I need to get a set of small metric sockets first.
It looks like the bolt holding the COP in place is a 6mm.
Old Nov 28, 2008 | 11:26 AM
Monsta's Avatar
Monsta
Sit. Stay.
Doubt it is the actually plug. Rarely do they go bad and create a misfire. Go buy two COPs because you're going to need them.
Get a universal joint, extension and deep socket to get to the rear plugs. If you're back there for #7 you might as well change 8, 9 & 10. There are a number wof threads addressing doing the plug on the V10 down in the V10 forum. have you found any to read yet?
And FTR, when I said a bad COP won't throw a code, I meant that it wouldn't light the CEL. *sheepish grin*
Old Nov 28, 2008 | 01:53 PM
bnuvp's Avatar
bnuvp
Well I changed all ten plugs (it was time anyway.)
Still got the missfire on 2 and 7.
Replaced the coils on 2 and 7, (jeez, that got easy), runs like a champ.
I'm going to stop at Autozone to check for codes one more time, just to make sure.
Changing plug 5 (left side, last one) is a chore.
They should put in an access panel from the glove box.
I couldn't be sure if I was changing the last plug or changing the left rear brake light.
I bet my neighbors were chuckling, seeing my legs sticking out from the engine, all covered in snow.....did I mention it's still snowing here? Probably won't stop till April.
mrjimbov
40
Mar 31, 2021 11:35 AM
twigsV10
Modular V10 (6.8l)
72
May 11, 2017 12:41 AM
Dave K
28
May 14, 2016 02:31 PM
knutson28
Jul 27, 2015 11:18 PM
General-Lee
Sep 11, 2009 04:15 PM
