help won't start
Old Nov 26, 2008 | 05:55 AM
plow truck's Avatar
plow truck
help won't start
I have an 89 3/4 ton w/302 She runs on spray in the throttle body and there's pressure on the fuel rail. Constant power on the injectors. But just won't run. Any suggestions.. Sat all summer (plow truck).
Old Nov 26, 2008 | 06:44 AM
Nitramjr's Avatar
Nitramjr
Gummed up injectors maybe? Possibly due to the reformulated gas sitting all summer.
Old Nov 26, 2008 | 05:48 PM
plow truck's Avatar
plow truck
Just checked with the right light and the injectors are'nt getting power.
Old Nov 26, 2008 | 05:51 PM
DJdemon6696's Avatar
DJdemon6696
is there spark? TFI module maybe?
Old Nov 26, 2008 | 05:55 PM
plow truck's Avatar
plow truck
yea theres spark in runs perfect on gas sprayed in the throttlebody. Pressure is good and just put in a new distributer module. still no power to injectors
Old Nov 26, 2008 | 06:07 PM
DJdemon6696
all relays working fine?
Old Nov 27, 2008 | 07:40 AM
chevenstein's Avatar
chevenstein
If it runs on gas spayed in the throttle body then you've got spark and compression, you're just missing fuel. If I'm thinking of the right kind of EFI system then you should get quick pulses on your test light with it hooked up to one of the injector while it turns over. No light or a solid light are bad. Assuming you have no light, pull the codes. My guess is a sensor or electrical connection has gone bad. Good luck.
