Broken bolt, Help.
Old Nov 25, 2008 | 04:10 PM
straightsixer's Avatar
straightsixer
Broken bolt, Help.
So, was removing the thermostat housing on my truck and one of the bolts broke off and left with about a 1/2" nub of a bolt. Tried putting JB Weld in an old socket and slipping over the nubbin' but its too cold here and the stuff won't setup. I've put heat to it, no worky. I'm thinking that if there's any hope at all then maybe I should take it to a garage before I totally bust off whats left. But before spending the money for a pro-mechanic does anyone have any ideas?
Old Nov 25, 2008 | 04:24 PM
danr1's Avatar
danr1
IF you don't have a acetylene torch to heat it with or a wire feed welder to weld a nut to it your probably not going to get it out and should take it in, or if you can rent or borrow one of the two.
If you're using a small hand held propane/map gas torch you'll never get it hot enough with it, may as well be using a bic lighter!
Anyway a full sized torch, a ice cube and a par of vise grips would get it right out.
Old Nov 25, 2008 | 05:31 PM
66F100Again's Avatar
66F100Again
More heat is always good, but I've had success with broken bolts with a Mapp torch. I've been paranoid of breaking the bolt a second time, so generally use lots of PB blaster, then heat, then cool, then heat...etc. I think the several temperature cycles cause enough expansion / contraction that it breaks the rust free. Then, vice grips and patience. If the vice grips don't immediately do the trick, remove and go through another heat cycle.
Old Nov 25, 2008 | 06:38 PM
05chop's Avatar
05chop
Use parrot nosed plyer from snap on or sears works better that vice grips.Then if no sucess get the drill out.Also grind the stud thats sticking out off till its flush with the block.Try a small drill bit then drill a hole then get a hi speed carbon bit and chip it out.
Old Nov 25, 2008 | 07:09 PM
RJG1987's Avatar
RJG1987
I like a lot of heat myself, thought i'd chime in, best of luck!
Old Nov 25, 2008 | 09:32 PM
justin_brandstein's Avatar
justin_brandstein
ez out/screw/ bolt extactors with heat work wonders.
Old Nov 26, 2008 | 01:25 PM
straightsixer
I've never used an ez-out before. Which is better, the one you pre drill a hole and screw in or the square type that you pound into the pre drilled hole? Figure I might only have one shot at this.
Old Nov 26, 2008 | 02:05 PM
paintslinga2010's Avatar
paintslinga2010
if you still have some sticking out, latch on as tight as possible with some vice grips before going with the easy out. I had the same problem and thats how i got it out, along with some heat and lots of pb blaster.
Old Nov 26, 2008 | 05:47 PM
quicklook2's Avatar
quicklook2
ez-out should be the last resort.
in many years and countless vehicles i have never used one.
heat/cold cycles, rust buster, and good vise grips is all you need.
when you put the new bolts in use anti-sieze on them.
Old Nov 27, 2008 | 06:26 AM
Opossum's Avatar
Opossum
I like the square ones alot better. And pounding them in tends to loosen the bolt. But that is the second choice.
First is heat and vice grips as these guys said. But here are some hard learned tips. If it's not obvious you are using the heat to expand the metal around the bolt so it will let go. So it is also important to keep the bolt as cool as possable. Second hit the top of the bolt with a hammer this tends to knock it loose. Last and most important, use vise grips with a square jaw and DO NOT just try and turn it out. Wiggle back and forth going a little to the left each time. And DO NOT let the vice grips turn on the bolt, if they turn on the bolt they will wear it smoother and smaller. Wiggle in one spot till the vice grips wear a flat on the side of the bolt then sighten up the grips and do it again. It will come out.
Of course all this is mute if you can just weld a nut onto the peice of the bolt.
