1bbl icing up
Old Nov 25, 2008 | 03:34 PM
twotired's Avatar
twotired
1bbl icing up
Friend of mine has 77 f-150 replaced carb with rebuilt one now its icing up at throttle plate any ideas ,base gaskets are new also checked for loose carb body bolts
Old Nov 25, 2008 | 05:40 PM
fmc400's Avatar
fmc400
MSEE
There is a hot-air duct system to prevent this. The air cleaner snorkel has a vacuum motor that opens and closes a door so that the carburetor only takes in warm air wafted from the exhaust manifold on startup. As the underhood temperature increases, a bimetallic vacuum switch on the air cleaner switches off the signal and lets the carburetor draw in fresh air from outside. Over time these parts wear out or are removed, but the factory setup is intended to prevent this situation.
