Average Oil Pressure
Old Nov 25, 2008 | 01:46 PM
matt71's Avatar
matt71
I replaced my original OP gauge with a 0-100 PSI mechanical autometer gauge. I screwed out the original OP sending unit and ran my fitting from there. I am seeing around 60-70 Psi on start up (its been aroound 30 degrees here during the day). I am running a 203 stat, when its up to operating temp (right around the "R" on the temp gauge) i see around 20-25 Psi idleing. Just wondering if this is ok, and what the other guys with aftermarket gauges are seeing for oil pressure. thanks
Old Nov 25, 2008 | 01:51 PM
Neal 97 250's Avatar
Neal 97 250
I see exactly what you are describing. Mine is read from the plug I removed by the oil filter.
Old Nov 25, 2008 | 01:56 PM
Cuda_jim's Avatar
Cuda_jim
Your good to go. The LPOP specs out at:
10 psi minimum @ idle
40-70 @ 3K RPM
Low oil pressure is not a concern with our rigs, if the LPOP stops pumping the injectors stop firing.
Old Nov 25, 2008 | 02:00 PM
Eric_F250's Avatar
Eric_F250
mine starts cold around 35, idles at 20 or so, and then bumps to about 50-55 at higher rpms.
Old Nov 25, 2008 | 04:44 PM
WALJON's Avatar
WALJON
I see exactly the same #s
Isn,t the 203* stat awesome? I love it one of the best mods I think for the money.
Old Nov 26, 2008 | 07:20 PM
matt71's Avatar
matt71
Yes I love the 203 stat mod! One of the best ones i did. It takes a bit to warm up to temp, but once it gets there you cant leave the heater on high for very long!
Old Nov 26, 2008 | 07:31 PM
WALJON's Avatar
WALJON
Yeah that's for sure I also notice it runs sooo much better especially idling
Old Nov 27, 2008 | 10:40 AM
larjoe's Avatar
larjoe
is this eng a 444e ?
Old Nov 27, 2008 | 11:15 AM
glasseater's Avatar
glasseater
yup it's a 7.3
