Flickering lights?
Old Nov 25, 2008 | 11:58 AM
boggerted's Avatar
boggerted
Flickering lights?
When I first start up my F250, all the lights will flicker as the truck runs. After driving for a few minutes it seems to get better. I cleaned the battery terminals, the starter and ground wires all look ok, and the ground wire seems to be attached securely to the block. What else should I look at?
Old Nov 25, 2008 | 02:31 PM
Ranger GT2's Avatar
Ranger GT2
Make sure you have a good ground to the body ,frame, and front grill area also. Possible bad light switch.
Old Nov 25, 2008 | 05:49 PM
bashby's Avatar
bashby
Do they kinda surge bright and dim or turn on and off at a random pace?A bad alternator will make them surge in a steady rythym
Old Nov 25, 2008 | 07:05 PM
Franklin2's Avatar
Franklin2
Run a ground wire from the voltage regulator mounting screw to a good ground. That usually takes care of it.
Old Nov 26, 2008 | 09:23 AM
pfogle's Avatar
pfogle
There SHOULD be a pigtail that's 10 or 12 gauge wire (been a while since I looked at one) on the ground wire. It needs to get bolted to the core support close to the voltage regulator. Without a proper ground it (the regulator) won't work.
1968 F100 Ranger
21
Jan 25, 2015 03:53 PM
d-day
Jan 7, 2014 12:31 AM
openscars
1983 - 2012 Ranger & B-Series
Jun 23, 2006 07:08 AM
dburke8088
May 22, 2006 01:55 PM
