6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Just installed PMT system, problems?
Old Nov 24, 2008 | 11:21 PM
kane gray's Avatar
kane gray
So I just installed the new PMT system for my 6.4 today. I have heard rumors of problems. How easy is it to bust your exhaust pipe joints? How hard can I be on the engine with the PMT. Exhaust is still stock. Will I crack the DPF with it? Just looking for feedback regarding a tuned 6.4, and any info about the bully dog PMT system would be much appreciated! Will this engine handle the extra HP and TQ better than the 6.0s, what about the extra boost pressures?
Thanks a bunch in advance!
Old Nov 25, 2008 | 10:30 PM
kane gray's Avatar
kane gray
So, today I have been playing around with the new programmer. It seems to be running ok, and it definitely makes a significant power difference, especially on extreme setting (which I will rarely use). I mainly am going to be using it for the added mpg. There definitely fells like significant blockage because of the DPF. The bully dog system itself is great, it worked flawlessly, and it utilizes the existing pyrometers, which makes the install relatively simple. Just worried about blowing something up that's all .
Old Nov 28, 2008 | 05:12 PM
BASSHUNTER's Avatar
BASSHUNTER
I have had the Bullydog PMT on my truck since it had 1900 miles and now have 21000 and no issues at all.Works real awesome.I run mine on extreme all the time and piro defuel at 1300.
Old Nov 28, 2008 | 07:33 PM
kane gray's Avatar
kane gray
That is nice to hear. Are your tail pipes black? And have you noticed your truck going into regen more often?
Old Nov 29, 2008 | 11:55 AM
BASSHUNTER's Avatar
BASSHUNTER
My tailpipes are not black or sooty at all,they are super clean.If you have the black sooty pipes i believe you probably have a cracked DPF.Mine goes into regen usually once a fillup.The PMT will show you that your truck is in regen.BullyDog has a great support group also.The origional R&D dept. is about an hour from me,and they have a great group of tech's. Good Luck!
Old Nov 29, 2008 | 02:07 PM
kane gray's Avatar
kane gray
Hey thanks for all the info. I haven't noticed much increase in the area of fuel economy yet, have you noticed a difference?
Old Nov 29, 2008 | 08:07 PM
BASSHUNTER's Avatar
BASSHUNTER
I get 11-12 around town driving and 13 -15 hiway depending on how fast i drive,At 80-85 i get 13 and at 55-65 i get 15,But i have lot's of power especially towing my boat or travel trailer.Maybe the new Reflash will help a little when it comes out.Like i tell my buddies if i bought the truck for mileage i would have bought an F150.But i bought it to tow and it does that very well.
