Sponsored by: Real Truck
8" Rize bumpsteer
Old Nov 24, 2008 | 08:31 PM
emmagator's Avatar
emmagator
8" Rize bumpsteer
Ok i have a 2006 f350 w/8" rize lift. When I hit dips or bumps the steering wheel turn, I figure its bumpsteer. Had the truck aligned, but still pulls to left, trying to find a quality alignment guy, anyway would the bad alignment cause this. If the truck is properly aligned will I still have bumpsteer. Would adjustable trac bar fix this, any advice would be great.
Thanks, DB
Old Nov 25, 2008 | 09:08 AM
emmagator's Avatar
emmagator
???? bump. Any advice
Old Nov 25, 2008 | 06:52 PM
Fordfanatic4life's Avatar
Fordfanatic4life
does ur kit have all the parts installed..
surely at 8" of lift there must be both pitman arm and track bracket parts....
u def. sound like u got bump steer..
got pics of ur front end by chance ???
i'd go to the Rize website (assuming they have one) and compare whats in their 8" kit with whats actualy on ur truck...
did u buy ur truck lifted or have it done ???
Old Nov 25, 2008 | 06:58 PM
DCSpecial's Avatar
DCSpecial
Stock stabilizer on the truck still?
Old Nov 25, 2008 | 08:07 PM
emmagator's Avatar
emmagator
Everything is installed. I have Rize dual stabilizer kit, no stock stabilizer.
Old Nov 25, 2008 | 09:21 PM
Fordfanatic4life
try contacting Rize directly..
if u have everything installed thats supposed to be there and still get bump steer, they should be able to give u some insite as to what might be wrong..
Old Nov 26, 2008 | 01:47 PM
skoveng's Avatar
skoveng
Bump steer occurs due to a front end geometry issue concerning the track arm and/or the steering drag link. The larger the angle from horizontal, the greater the bump steer; the flatter the angle the less bump steer. The track arm and steering drag link wants to move in an arc when the suspension compresses. As the axle wants to move straight up (due to the springs) it forces the track arm and/or steering drag link to move to the left causing the problem. You’ll need to either drop the track arm bracket at the frame and/or use a drop pitman arm off of the steer box. More radical lifts also require relocating the track arm bracket at the axle and moving the drag link locating point at the right steering knuckle. Good luck.
