engine offset discussion
Old Nov 24, 2008 | 08:07 PM
woodyf1's Avatar
woodyf1
what about engine offset i just got a 9 inch out of a 68 ford f100 i noticed that the pinion is off center by 4 inches doesthis mean that the engine and trans has to move over by the same amount i know the up down pinion angle is critical what about side to side any info
Old Nov 24, 2008 | 09:02 PM
jniolon's Avatar
jniolon
old and in the way
woody...
your engine center line does not have to match your rear end center line
I doubt that you could get 4" of offset between the frame rails. 4" sounds like a lot... where are you taking your measurements ?? I'm just curious.
You didn't mention which engine you're using.... but if it will sit centered in the frame rails and you have steering linkage and header clearance and clearance on anything else... you don't need to offset at all... Just maintain the parallel center lines for engine and rear end... same on pinion angles...
this might give you some visual help
http://www.clubfte.com/users/jniolon...nephasing.html
later
John
Old Nov 24, 2008 | 09:08 PM
woodyf1's Avatar
woodyf1
im using a 302 with aod i measured the pinion centre between the backplates on my 68 ford pu 9 inch
Old Nov 25, 2008 | 10:36 AM
mcdonaldm's Avatar
mcdonaldm
with trucks centering the pinion is not as important as with a car. in a car the driveshaft has to run down the centre of the car through the tunnel, so the pinion is centered. that involves making one axle longer than the other.
on trucks the driveshaft doesn't have to run down a tunnel so Ford decided to make both axles the same lenght instead and that makes the pinion offset to one side. Since the driveshaft hangs down below the body, the driveshaft can run at an angle back to the rear end. where you place the engine is not critical as long as the centerline of the engine (crankshaft) is at a right angle (or parallel) to the rear end centreline. that is the engine should be parallel to the frame rails and not at an angle. this reduces vibration in the drivetrain. so you can offset the engine to gain clearance for headers or sterring box, etc.
hope that makes sense.
rgds
Mike
Old Nov 25, 2008 | 11:16 AM
woodyf1's Avatar
woodyf1
thanx you guys are always so helpfull
ToddMyers58
Feb 20, 2017 12:20 PM
Jesses1999f250
Feb 19, 2016 11:03 AM
patience
20
Oct 14, 2015 07:19 AM
sdloe
13
Dec 17, 2011 07:47 AM
ricklong
6.7L Power Stroke Diesel
Mar 7, 2011 10:53 AM
