Proportioniong Valve question
Three questions:
1. Will a proportioning valve from a 76-79 F150/Bronco work? (I did see one of these on the shelf and it certainly looks the same from the outside).
2. What other years will work and does anyone have one for sale?
3. Can they be taken apart and cleaned/rebuilt?
Any help would be appreciated.
Thanks!
John
http://i135.photobucket.com/albums/q...h_IMG00252.jpg
Three questions:
EOTZ2B257A .. Brake Differential Proportioning Valve / Obsolete
Fits: 1980/83 F100/150 & Bronco / 1980/83 F250 = under 8500 lbs. GVW.
Sorry....No Ford dealer or obsolete parts vendor has any.
i drove it today for the first time in the snow and it was quite a ride with only the fronts trying to stop the truck, and the rears just kept spinning on the ice/snow. even with the pedal to the floor the rear brake pressure wasn't enough to stop them from rotating at idle in drive.
if you have any other ideas I like to hear them.
anyone have an extra prop valve for sale from a 80-83 F100 or F150 or F250 (under 8700)?
John
You could also just take it out, and install a manually adjustable aftermarket valve in the rear line. They sell them at summit racing. Race cars use them all the time to balance the rear to front braking.
Here's one. You made need some adapters for the lines.
http://store.summitracing.com/partde...5&autoview=sku
Here's another that might have a simpler hookup.
Now I'm not sure if the F100 one does all of this, but here's some of the functions the prop valve might perform:
1. Drum brakes and disc brakes require different amounts of force (line pressure) to activate them. Due to the drum brake shoe's leading edge 'digging into' the drum it requires less force to make it work which is why (most) drum systems do not need to use a vacuum booster. The proportioning valve provides a lower pressure to the rear lines, otherwise they will tend to lock first (which is very bad!).
2. The proportioning valve may also be used to hold residual pressure in the rear line to prevent the springs inside the rear drum from pulling the shoes too far away from the drum. If the shoes get too far away from the drum you will have to pump the brakes to get a solid pedal every time you go to stop. Disc brakes have no active measure (springs) to push the pistons back in the calipers, they rely on sloppiness in the bearings and an allowable disc 'runout' to release brake pressure on the disc. They don't need residual line pressure to prevent the pads moving too far away from the disc.
3. The proportioning valve usually also contains a piston separating the front and rear brake circuits. If for whatever reason one of the circuits has a catastrophic failure, the high pressure from the good circuit will push the piston to the 'bad' side and it will block off the outlet. This keeps the master cylinder from draining completely and leaves you with at least some braking ability.
4. It may also be used to provide a delay to the front brakes to let the rear ones come on first, but I think this is taken care of in the master cylinder in the F100
If the earlier F100's had identical brakes to yours you should be able to use one of their valves. Maybe the mounting is different. These guys might be of some assistance Proportioning Valves
EOTZ2B257A: 1980/83 F/U100/250 under 8500 lbs. GVW
This is the only valve listed for a 1980/83 F100.
This is the only valve listed for a 1980/83 F150.
This is the only valve listed for a 1980/83 U150 = BRONCO.
This in one of two valves listed for an F250.
1984/86 Bronco uses the same valve an F150 2WD/4WD does: E4TZ2B257B
1976/79 Bronco uses the same valve a 1975/79 F100/250 2WD/4WD does: D5TZ2B257B
I disagree with this. Mis-adjusted shoes are the #1 cause of a low brake pedal. Residual valves, if any are used are mounted in the mastercylinder port, and their only purpose is to keep the cup seals out against the wheel cylinder bore.
I disagree. There is a piston in the proportioning valve separating the two circuits, but it's only purpose is to turn the "brake" dash light on. Ask anyone who lives in a area were they spread salt on the roads, when the rear line rusts and springs a leak, you will lose ALL of the brake fluid in the rear resevoir of the mastercylinder.
I have heard of this before, and cannot say whether it does this or not. Some people think the rear needs to "lead" the front to provide straight braking. All I know is the rear locking up during a panic stop will make the rearend come around, and you will end up pointed in the opposite direction you were originally headed.
