steering column question
Old Nov 23, 2008 | 09:26 PM
joosephk's Avatar
joosephk
I have a 67 F-100 that I'm having a problem with. The steering wheel is riding up to the point where my turn signal pins on the wheel will no longer make contact with the cam on the switch. I've tried loosening the two bolts under the dash and pulling the column up tigher to the wheel but it is causing the rag joint to distort. Is there an adjustment on the bottom of the column yhat could be tightened? Thanks for any help.
Old Nov 25, 2008 | 08:48 AM
Freightrain's Avatar
Freightrain
There is a clamp around the base, but not much room to move things around. Sounds like your cab mounts are starting to settle?
Welcome to FTE!
Old Nov 25, 2008 | 12:24 PM
camperspecial65's Avatar
camperspecial65
Yes...loosen the clamp as mentioned under the hood...as I recall its a 9/16 and a carriage bolt...loosen that plenty and loosen the 2 bolts holding the column to the dash/pedal assembly and it should move alot easier. If that doesnt help any, and if you havent already, check the cab mount there for settling.
- cs65
