Need help with hubs.
Old Nov 23, 2008 | 07:48 PM
russandirene's Avatar
russandirene
Hi all,
I'm in trouble.
I repaced the rotors on my 93 f-150 4x4.
but I screwed up ,got it all together and now can pull on the cover of the auto hubs and it falls off the truck!
any idea what I dad wrong.
It has 5 screws holding it on,but it all fell off. the rotor is secure to the truck,and the wheel will not fall off,but the auto hub did.
please help.
Thanks russ
Old Nov 23, 2008 | 07:52 PM
95F350XL's Avatar
95F350XL
Did you put it back together the way you took it apart? Did all the snap rings click in?
Old Nov 23, 2008 | 07:53 PM
xltlariat87's Avatar
xltlariat87
should be a clip that holds the hub on the axle
Old Nov 23, 2008 | 08:35 PM
Dre82s's Avatar
Dre82s
I never owned a auto hub truck but the manual hubs have clips and a phillips screW. best of luck
Old Nov 23, 2008 | 11:07 PM
1966Tbird's Avatar
1966Tbird
if you want i have another set of auto hubs you can have for shipping when i go home for thanksgiving, they need cleaned out badly though. and DON'T use wheel bearing grease anywhere near the hubs they will stop working....ask why my auto hubs need cleaning out lol, i just swapped to manual hubs cause i didn't like the auto ones anyway
Old Nov 24, 2008 | 09:34 AM
njtinman2's Avatar
njtinman2
should be a big ring at the end of the hub *** that is part of the rotor that holds the locking *** in before the outside cover goes on
