are you in need of just the 2 cables from the battery to ground and battery to the starter relay or do you also seek the cable from the starter to the starter relay ???
Also, if your cables are originals, there will be a part number or engineering number stenciled on the cales covering thoughout its length...if you find these numbers, post them for proper ID/crossover.
- cs65
Reason: added info
