4X4 question
Old Nov 23, 2008 | 02:00 PM
blloyd's Avatar
blloyd
4X4 question
I sold my 1972 F-250 about a year ago, so I could buy a 1988 F-250HD 4X4.
I really miss my 72 and am not a big fan of the 1988, which made me wonder if it is possible to put the 72 body on an 88 frame.
I guess I should check in with the 87-96 form also !
Thanks
Old Nov 24, 2008 | 01:02 PM
BradyCouchman's Avatar
BradyCouchman
the body mounts are not in the right place, but i am almost 100% sure the frame rails are the same distant apart, you would need to have the same cab bed config on both trucks, or be willing to cut the frame......and the crew cab long bed i know are the same wheel base on both trucks...i think it might be possible but have never done it.
Old Nov 24, 2008 | 02:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The rear frame rails of 1967/72 F100/350 2WD's / 1967/72 F100 4WD's / 1967/77 F250 4WD HIGH BOYS are 33 1/2" wide, also some F350's used this same frame width thru 1979.
You won't find the frame rails of any truck after 1979 with that narrow rear frame.
Measure your Crew Cab frame rail width, Brady...it's the same = 33 1/2"
Old Nov 24, 2008 | 03:13 PM
BradyCouchman
all i know is i bought a front light bar that bolted to the frame/bumper mount and it was for a mid 90s F350. and it fit just fine.
Old Nov 24, 2008 | 03:38 PM
jowilker's Avatar
jowilker
Thanks
Absolutely it is possible. You will need to be a little creative, but it can be done.
John
Old Nov 24, 2008 | 03:53 PM
BradyCouchman
the only other thing that is not as much physical is the law. when you go to register the truck you might end up in trouble......
Old Nov 24, 2008 | 05:02 PM
jowilker's Avatar
jowilker
In our state they have a way to deal with that too, they will issue you a new North Carolina VIN number.
John
Old Nov 24, 2008 | 05:16 PM
NumberDummy
Ain't that a kick in the head!
Brady, I think you ate too many Cheese-Its at our last Chapter GTG, and they fried your brain.
Either that or you are suffering from myopia after spending your entire day on FTE!
The REAR FRAME rails are 33 1/2" inches wide.
I said nothing about the front rails. They are the same width 1967/79.
Old Nov 24, 2008 | 05:58 PM
BradyCouchman
the nice thing about the rear rails is that the bed is a lot simpler to mount then the cab would be.....sorry bill missed that wording in your first post.....oh and btw the cheese its no one opened them even
Old Nov 24, 2008 | 06:18 PM
tin-man's Avatar
tin-man
It may end up like that Cadillac Johnny Cash built one piece at a time
Old Nov 25, 2008 | 09:57 AM
BradyCouchman
that is a great song david!
Old Nov 25, 2008 | 07:47 PM
scottfreeman's Avatar
scottfreeman
My favorite song, in fact. All of my vehicles are pieced together conglomerations....
Old Nov 25, 2008 | 08:25 PM
tin-man's Avatar
tin-man
Build it like YOU want it, after all you are the one you are trying to please!!
