95 Bronco 5.8L 351....problems!!!
Old Nov 21, 2008 | 08:41 PM
bronco958495's Avatar
bronco958495
My Bronco just started acting up tonight. It's idling really rough like it wants to killout, but when given the gas it starts to run fairly decent. Also at the same time this happened my brakes went out and I have to almost stand on 'em to get her to stop. I noticed when I stopped and got out of it, it had a real bad fuel smell out of the exhaust, I drove it home approx. about 10 min. and then got out of the truck and the smell turned to a burnt smell. Please help!!!
Bryan
Old Nov 21, 2008 | 09:00 PM
95F350XL's Avatar
95F350XL
Ck your brake booster line. It might have broke or opened up and is creating a massive vacuum leak, causing it to run rich, and run like junk. Is the brake pedal hard?
Old Nov 21, 2008 | 09:02 PM
bronco958495
Brake pedal is extremely hard!!!
Old Nov 21, 2008 | 09:13 PM
1966Tbird's Avatar
1966Tbird
yeah check the line off the booster
Old Nov 21, 2008 | 09:26 PM
bronco958495
Well I'll be Damned! I think I'd like to buy ya'll a beer or 12! I'm not a real "mechanical" type of guy, but that sonofabitch was unplugged from the throttle body. I thought for sure it was gonna be a hell of a ****load of money to fix that thing the way it was running. Thanks is an understatement guys. Ya'll rock!
Bryan
P.S. just to let ya'll know, It's cold as ****cicles down here in Louisiana.
Thanks Again!
Old Nov 21, 2008 | 09:36 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
That what happened to my friend's 2001 F250 that run so bad plus brake so weak that you need pump to get stop.
Found that they remove pvc valve out valve cover and wrap in air filter's housing. I was little angry when saw that.
Lucky engine run ok.
Old Nov 22, 2008 | 09:23 AM
bronco958495
Now, I'm not too sure that you can blame being deaf on you're grammar. Last time I checked, it doesn't take you're ears to read and write, but why would I "not" be okay with you being deaf!!!!
Anyways....
Thanks for the insight to the truck though. You're opinion and statements will not be ignored.
Bryan
