Help please. Purchased truck and it seems to mis-fire or run out of fuel when driving on different times. It also looses power at that time. It runs fine when not acting up. Only acts up for about a minute. Read codes before replacing parts fuel pressure regulator, fuel filter, MAF sensor, dist cap & rotor button and ignition coil. Codes were 332, 538, 536 and 632. Checked TPS and its fine. Your suggestions will be very much apreciated. Thanks
Friends,
Thank you all who replyed to my forum. I very much apreciate all your response and valuable knowledge. This evening I replaced the spark plugs, ignition wires and o2 sensor. The result is she is purring like a kitten and has the power of a lion. I am very pleased and pat yourselves on the back for a job well done.
