Sponsored by: Auxito
1997 front brakes
Old Nov 21, 2008 | 11:46 AM
Chuck G's Avatar
Chuck G
1997 front brakes
I see i have a bad brake pad on the left front is it difficult to replace these pads ? Whats steps ? Is the front spindle nut metric? Can i use a C- clamp to compress caliper? thanks for the help.
Old Nov 21, 2008 | 09:22 PM
firefighter1416's Avatar
firefighter1416
odds are the spindle nut is metric but you don;t need to do anything with the spindle unless you have a wheel bearing out but the pads are pretty easy to change you can use a c clamp depress the calipers, when you take the calipers off be sure to use some synthetic grease on the pins the calipers slide on this will save a lot of head aches later as they will stick and squeek. you could even go as far as to put a dab of grease in the slots the brakes set in. I did on mine and they are really quiet
