Sponsored by: Kumho
Leveling Kit Question
Old Jun 15, 2002 | 07:30 AM
doorslammer's Avatar
doorslammer
If I install a 2.5” leveling kit on the front of my F350 SD, will it change the angle of the front pinion and front drive shaft? Will I have to make any changes to them as well? I would appreciate any feedback from those of you who have installed a leveling kit. Thanks!
Doorslammer
F350 Power Stroke
Crew Cab
Old Jun 15, 2002 | 06:48 PM
AZ4x4f150's Avatar
AZ4x4f150
[updated:LAST EDITED ON 15-Jun-02 AT 07:50 PM (EST)]your're driveline angle should be fine you didn't go up high enough to make a difference. 4" or higher is where you need to worry. that is if you don't have a double cardan joint in your driveline or a 2 piece drive line for the front. A standard u-joint can handle up to 3 degrees of angle before you need to change pinion hieght
Old Jun 15, 2002 | 08:36 PM
MustangGT221's Avatar
MustangGT221
Big Red F250 SD
6.7L Power Stroke Diesel
26
Dec 17, 2020 09:57 AM
woody_cody
Apr 12, 2015 11:46 PM
98woody
22
Sep 30, 2013 03:26 AM
tlc3810
Aug 27, 2011 08:32 PM
utjer
Apr 8, 2010 04:55 PM
