running lean
Old Nov 20, 2008 | 06:07 PM
technomon's Avatar
technomon
running lean
ive got a 1997 explorer 4.0 auto i keep getting code po174 and po171 the book says the engine is running lean i keep deleting them but they come right back the car seems to run ok which sensors do i need to check any ideas thanks alot
Old Nov 21, 2008 | 10:25 AM
Bear River's Avatar
Bear River
Former ******
Lean codes on both banks typically indicate a major intake or vacuum leak, but can also indicate a dirty MAf sensor. The best course of action is to clean the MAF sensor, and then replace any questionable vacuum lines. The intake manifolds gaskets are a common failure, so if there are no vacuum leaks and the MAF isn't the cause, the intake manifold gaskets will need to be replaced.
Old Nov 21, 2008 | 01:46 PM
aquanaut20's Avatar
aquanaut20
Ditto Bear's advice, have had a couple leak by the FI O-rings, so check them and if you do the intake manifold gaskets , replace the O-rings.
I ended up making a smoke machine for the last leaker (couldn't locate leak)
Jim40216
Sep 8, 2016 01:52 PM
RDockery
May 27, 2016 12:19 PM
Mr f250
Feb 21, 2016 11:25 PM
blue&white
1978 - 1996 Big Bronco
Apr 9, 2008 10:32 AM
edenges
1997 - 2003 F150
Mar 22, 2005 06:48 AM
