New (to me) problem
Old Nov 19, 2008 | 07:11 PM
dsquared's Avatar
dsquared
New (to me) problem
I was driving home yesterday, and there is a backway short cut I take to avoid a couple PITA traffic lights. The road is paved, but really broken and rough in spots. Anyway, as I was driving on it, I lost all power. There is a 90° right at the end of the road, so I muscled through it, and stopped at the side. I immediately thought CPS. I tried cranking, and it spun great, just no fire. I turned it off, sat a minute, and tried again. Still nothing! But wait!! What's this?!! My F5 was not lit!! I checked, and the cable had shaken itself loose from the switch!! Plugged it back in, fired right up, and life is good again!!!
Haven't seen anyone else have this problem yet. So if it happened to me, it could happen to you!!
Old Nov 19, 2008 | 07:16 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Glad you figured this out Don. We all know that if you take the F-5 controller off, you get no start. I am sure this has happened to some on here, but like you they figured it out.
Old Nov 19, 2008 | 08:23 PM
wilbur996's Avatar
wilbur996
OK, you got me, what is an F-5 controller?
Old Nov 19, 2008 | 08:33 PM
miller_feed
That is what you use to change tunes on the DP-TUNER. It can hold 16 diffrent tunes, and you just push the button to change tunes.
Old Nov 19, 2008 | 08:36 PM
miller_feed
Look here, look at the switch. That is what we are talking about. click here
Old Nov 19, 2008 | 08:43 PM
wilbur996's Avatar
wilbur996
Now I know! Thanks!
Old Nov 19, 2008 | 09:39 PM
jdecker88's Avatar
jdecker88
If your F5 switch is disconnected your truck will die and not start back because it automaticly sets the truck to position 0 which is nostart, trust me when I first got DP I was playing with it in my hand and shut the truck off.
Old Nov 19, 2008 | 10:05 PM
Ponyboychris's Avatar
Ponyboychris
I drive quite a few bumpy roads up in the hills to get to my land. I guess I need to keep an eye on this.
HokieHiVPI
May 4, 2020 01:36 PM
carletonmielke
Apr 9, 2016 09:48 PM
Newby87
33
Feb 26, 2016 12:35 PM
bluetruk88
Dec 2, 2012 06:50 AM
cappyd892
Jan 17, 2010 02:26 AM
