Sponsored by: Auxito
There has to be
Old Nov 19, 2008 | 02:07 PM
kaboom10's Avatar
kaboom10
There has to be
a place to put rear end lube in and ck the level. I have a 02 F-150 5.4L w/ a 9.75" rear end. It's the FX4 model with the towing package. I looked for the fill plug that the book said it would be but it's not there. I looked all over the thing the best I could while under the truck not up in the air. ??????? where????????? is it???????
Old Nov 19, 2008 | 02:27 PM
KingRanchMan02's Avatar
KingRanchMan02
Driver's side of the axle, on the front (pinion side) under the strengthening rib.
Old Nov 19, 2008 | 02:36 PM
kaboom10's Avatar
kaboom10
That's the first place I went since it showed it in the repair manual. I must be blind then. It says to use the square end of a 3/8" drive extension.
Old Nov 19, 2008 | 02:54 PM
KingRanchMan02
Scratch around there with a pick or screwdriver to uncover it from the mud and muck that it may have picked up while off road. Good luck!
