is 4x4 problematic???
Old Nov 18, 2008 | 03:32 PM
simolosovich's Avatar
simolosovich
I'm looking at f150's to tow my aluminum bass boat.
The thought of 4x4 sounds nice, as I could got to just about any ramp I would ever want to...BUT...could possibly never need it.
That being said, should you generally stay away from 4x4 unless totally necessary, assuming it means more overhead in the long run?
Thanks for advice!
Old Nov 18, 2008 | 04:31 PM
Tom's Avatar
Tom
While you may read of problems with the 4x4s on many forums, most of us find that it's a pretty reliable system. I believe it's covered by the 6/60 powertain warranty that comes with all new Fords, so at the very least you shouldn't have to worry about it for awhile.
Old Nov 18, 2008 | 05:18 PM
glankerglanker's Avatar
glankerglanker
If you are thinking about buying 4x4 just to help pull your boat up the ramp, I would suggest against it. I've pulled all different sizes of boats out of a lot of different ramps, and I have never needed to put any of the trucks in 4x4 to get the boats out.
Old Nov 18, 2008 | 05:59 PM
Ryan50hrl's Avatar
Ryan50hrl
I'd say go for it, i've never had a 4x4 problem (short of my 95, but that was a custom 4x4 job with an axle swap) on any of my trucks, and 4x4 has saved me more than once, i've used it to pull boats out of the water, and even pull another boat and truck (2wd dodge) out of the ramp, he had slid far enough down to have the front wheels underwater......That was fun....
Old Nov 18, 2008 | 06:02 PM
Tom's Avatar
Tom
Better to have and not need, than to need and not have....or something like that!
Seriously, I like 2WD trucks because they're cheaper and they get marginally better MPGs. If I knew I'd never need the 4x4, I'd have saved my $3,000 and gone 2WD.
But, my occasional use makes it worth every penny
Old Nov 18, 2008 | 06:06 PM
jgh2k's Avatar
jgh2k
For the bit of extra money it is, I have always found it to be good insurance when it's needed.
Old Nov 18, 2008 | 06:42 PM
silver05fx4's Avatar
silver05fx4
well one day your gonna say why did't i buy that 4x4 when your stuck
well from my boating expertice is a very use full thing ...once i was backing down the the ramp with the boat at the launch and stop started to get out to unhook the lines from the boat to the trailer and just as i step out the truck started to drift back . the rear tires had just got on the edge on the slime on the ramp so hit the brakes and then seeing what happen hit it in 4x4 pulled back out on to better ground ..now to say that might happen to you...the boat was a pontoon that weighted 3000 lbs
i've seen it happen to a few trucks ...they just get it the wet and slide right back ..i even seen a boat and truck sink ..it cause us not to go on the lake one saturday
Old Nov 18, 2008 | 07:00 PM
4DOORSR's Avatar
4DOORSR
Nothing beats the old stick on the floor. I've never had a problem with 4x4 other than vacuum line or solenoid stuff. Usually not expensive fixes, but always a pain in the *** when it lets you down at the worst of times...
Old Nov 18, 2008 | 11:04 PM
hillbilly12384's Avatar
hillbilly12384
i have always liked 4x4 just cuz you have it in case you need it or get the urge to play in the mud :-) or if you have to pull a chevy out
Old Nov 19, 2008 | 01:03 AM
Tees77f150's Avatar
Tees77f150
Funny, I have been tossing the same issue around in my head for a while now. I bought my truck new in 96, and it doesn’t give me ANY problems, and there has been no truck payment for several years now!!
But I anticipate with in the next few years I may be looking to up grade. I pretty much decided not to go new the next time, but the 4X4 I am still tossing around. I know it is great when you need it, but that wouldn't be but a few times a year (talking weather conditions) is it worth it for the extra expense on the initial purchase, gas mileage and maintenance?
I owned a 4X4 before, and did enjoy its benefits. I guess I still have time, so the jury is still out on this one.
Old Nov 19, 2008 | 01:41 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
the choice between 4x4 and 4x2 is simple for me.
I may never ever need to use 4x4. But the 1 time I need it, and don't have the 4x4...= a very bad day. I made the 4x2 mistake 1 time. Never been back down that road since.
IMO it's better to fork over the little bit extra money and never use it. The 1 time you do use it, the 4x4 has paid for itself.
Old Nov 19, 2008 | 08:22 AM
Fishin76's Avatar
Fishin76
Here, Here! I am in total agreement with Tylus. Just the fact that I can be depended upon to be somewhere in the worst of weather or conditions is enough for me.
I'll never not have a 4x4 again. It has come in handy too many times not to have it on at least one of my vehicle from now on.
Again, jut my .02.
Old Nov 19, 2008 | 07:05 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
go for the 4x4 man...first truck i've owned with it, no problems at all, and pulled me out of at least 6 snow jams!
Old Nov 19, 2008 | 09:28 PM
3155944's Avatar
3155944
4x4
local guy in town was on the boat ramp pulling out and his rear drive snapped. the front wheels pulled out and saved the day.he has a bronco
