Sponsored by: Kumho
will they fit
Old Nov 18, 2008 | 02:48 PM
Tony85f150's Avatar
Tony85f150
will they fit
hey im new here i have a 1985 f150 2wd with a stock suspension i want to know if 33x12.5x15 fit on the front of the truck cause they fit nicely in back can someone help???
Tony
Old Nov 19, 2008 | 10:20 AM
9.ford.5's Avatar
9.ford.5
stick it in a shop lift it till susp. is at full sag change em out set the truck down check everything then crank th wheels both ways check for rubbing...i can tell you right now if they do fit you wont have **** for travel up front before the will be hittin wheel wells
