Sponsored by: Auxito
Fuse Panel Diagram
Old Nov 18, 2008 | 10:39 AM
John Luther's Avatar
John Luther
Fuse Panel Diagram
Looking for the diagram to the fuse panel, both underdash and engine compartment. Heater quit working and before I tear apart the dash I want to check the fuses. Lost owners manuel. I also want to know if any of the "relays" in the fuse boxes control the heater. Seems possibly the blend door is not operating. Thanks in advance.
Old Nov 19, 2008 | 07:51 AM
projectSHO89's Avatar
projectSHO89
Download a copy of owner's manual: www.fleet.ford.com under Maintenance
Old Nov 19, 2008 | 01:01 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
What are your symtoms, no blower speeds, one blower speed only, no hot air, no cold air? You may be looking in the wrong area. We can probably help you if you give us information. Dan.
Old Nov 19, 2008 | 01:39 PM
KingRanchMan02's Avatar
KingRanchMan02
Yep, it might be a simple burned out blower motor resistor pack. Good luck!
Old Nov 19, 2008 | 08:34 PM
John Luther
Blower works fine on all speeds. The panel/floor/defrost switch works great. It's just when I turn the temp from cold to hot, nothing happens. I have the dash pretty much torn apart but I cant seem to see the misteryous "blend door". A/C works great as well...
Old Nov 20, 2008 | 08:43 AM
KingRanchMan02
Swap the temperature **** with the fan **** and see if that gets you some heat. The ***** tend to split and won't hold the switch shaft tightly. The temperature control is a bit stiff to turn, so when the **** splits, the temperature control can't be adjusted. Good luck!
Old Nov 21, 2008 | 01:25 PM
Parts Guy Wyatt
Former Vendor
The blend door is inside off the heater plenum ( big black box). You may have a bad blend door or a bad blend door motor. If you will tell me the year, make, and model of your truck I can tell you where the blend door motor is located so you can check the function of it and the blend door. Dan.
Old Nov 22, 2008 | 06:49 AM
projectSHO89
See the FAQs posted at the top of the HVAC forum.... which is the most appropriate place for conversations regarding HVAC issues
Steve
White Boy
Apr 25, 2013 08:24 AM
White Boy
Jan 21, 2012 09:02 AM
1978-BBB
Oct 30, 2011 05:34 PM
jds80021
Dec 25, 2005 12:50 PM
cabronco
1966 - 1977 Early Broncos
Jul 8, 2004 08:43 AM
