tps
Old Nov 18, 2008 | 09:31 AM
Upper's Avatar
Upper
tps
Hellow all,I have a 97 250 powerstroke 230k.Bought the truck with 220k and love it but,when idleing around the rpms go from 700 to 1200 with no in-between.Also is there a realationship between the TPS and the clutch,as in 5 speed..Thanks Upper
Old Nov 18, 2008 | 10:15 AM
Neal 97 250's Avatar
Neal 97 250
Welcome to FTE.
There is no relationship between the tps and clutch. The clutch is all manual and the TPS is all wires.
When you say idling do you mean you are not touching the throttle at all?
Old Nov 18, 2008 | 10:52 AM
Hussler's Avatar
Hussler
Sounds like the IVS (idle validation switch) is not closing when releasing the go peddle.
Old Nov 18, 2008 | 11:51 AM
Upper's Avatar
Upper
It is when I am going slow on rough roadsIt is either 700 rpms or 1300 rpms,nothing in between.It can be like dried meat,Jerky..........Upper
Old Nov 18, 2008 | 05:39 PM
plowhand's Avatar
plowhand
Playing in the Dirt
I second the IVS. This might help (copied from Baz's site Tips - Idea - Hints )
Accelerator Adjustment
In some cases, the accelerator sensor doesn't respond as it should. You may notice it clicking or hesitating when you push on it. The accelerator on the Power Stroke is completely electronic, there is no throttle cable. This sensor can be adjusted for better throttle response. Go easy though, if you adjust it too far, you may have a problem with the engine resetting to idle. There is no adjustment on the switch. I had to bend the tab on the accelerator that depresses the switch until I was satisfied. WHAT A DIFFERENCE!!! It's nice to have throttle control.
Bend the tab on the pedal until it is set so that as soon as you depress the pedal the IVS clicks. Good Luck.
Old Nov 19, 2008 | 04:33 PM
Welk49's Avatar
Welk49
I'll have to check that out as well I have had same problems when it's idling it will jump rpm, sometimes it acts as though it's going to die, then while at stop lights it revs up like it wants to take off.
