heater core question
Old Nov 17, 2008 | 11:48 PM
windsor94's Avatar
windsor94
I have a 94 F250W. Single cab. Is the heater core a engine compartment mounted or is it cab mounted? How will I know? I need to replace it. I have the hoses off and they are joined together to stop the leaking.
Old Nov 17, 2008 | 11:51 PM
geo455's Avatar
geo455
It's cab-mounted, directly behind the glove box.
Old Nov 18, 2008 | 02:24 AM
jnewkirk77's Avatar
jnewkirk77
I don't know if it's identical to the setup in my '87, but you can't get one much easier to replace. I think mine took maybe 30 minutes start to finish, but my coolant was good, and I didn't lose much.
Of course, make sure you get the right core wherever you go ... Advance sold me the wrong one the first time!
Old Nov 18, 2008 | 07:11 AM
lilwitchfromok's Avatar
lilwitchfromok
just replaced mine easy job behind glove box in cab 7-8 mm seven bolts.
Old Nov 18, 2008 | 11:16 AM
quicklook2's Avatar
quicklook2
open glove box, take contents out, press in on sides to have it move out of the way.
remove the plate you see, 7 screws i think.
remove core.
check that flapper door works and is not obstructed.
reverse order.
Old Nov 28, 2008 | 02:04 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
That's funny, I had to replace my heated core today after reading this just a few days ago. Noticed a slight scent of antifreeze and a slick film on my windshield. Went to NAPA bought the core and 20 minutes later the job was done.
Tim
abyars111
Nov 13, 2013 08:06 AM
89ranger/93f150
Sep 20, 2006 07:13 PM
buttz
Sep 7, 2006 09:10 PM
merlynr
Mar 15, 2006 05:24 PM
Cajunrail
Feb 25, 2004 12:19 PM
