Heater not very hot??
Old Nov 17, 2008 | 10:35 PM
alconk's Avatar
alconk
I have a 79 sb with a 302 and now that were going into winter I've had to use the heater but it does not get hot hot like my other vehicles. I also had another 79 with a six last winter and it had a new radiator, heater core and it was the same way. Is this normal for these trucks? What can I do to stay cozy warm this winter?? My plans for this weekend is to have the original rad. boiled out and to get a new heater core so maybe that will help???? Or what if instead of a standard heater core to get the extreme heater core? Will it fit with no mods??
Old Nov 17, 2008 | 10:39 PM
pfogle's Avatar
pfogle
Do you have a clutched fan or a straight fan? Look at the fan on the engine, is there a thermal clutch (big aluminum disk with fins attached to the fan) or is it just a spacer and fan bolted to the water pump? If it's the latter you can try putting some cardboard in front of the radiator to restrict the air flow. Does the heat come and go with the thermostat opening? You may also have a plugged heater core.
Old Nov 17, 2008 | 10:44 PM
alconk's Avatar
alconk
I have a straight fan with no clutch, I would try the cardboard but the temp gauge already runs to the hot side. I have a new water pump, thermostat (195) and the system has been flushed. It was very dirty....The heat stays the same it's just not very hot..
Old Nov 17, 2008 | 10:46 PM
pfogle's Avatar
pfogle
That sounds like a plugged up heater core. Take a garden hose and cut the end off it, un hook the heater hoses from the core, and back flush it. Hook the garden hose to the bottom pipe on the heater core and see how much crap you can get to come out. It might help for a bit until you can get a new heater core.
Old Nov 17, 2008 | 10:55 PM
alconk's Avatar
alconk
Could be?? If you feel the heater hoses they are extremely hot like the rad. hoses. so something is not doing there job... So if the system is working properly working I should have the hot heat I'm looking for right??
Old Nov 17, 2008 | 10:57 PM
pfogle's Avatar
pfogle
Check the blend door, make sure it's moving. I had this problem after putting a new heater core in a '82 E350, the blend door got bound up when I reinstalled. I had to grab the lever on the top of the box and move it manually to free it up. Then I had all the heat in the world.
Old Nov 17, 2008 | 11:01 PM
alconk's Avatar
alconk
Actually I had the whole heater box assembly out a few months back restoring it and ******* me did not replace the heater core. The blend door and temp door operate very smoothly.
Old Nov 17, 2008 | 11:26 PM
pfogle's Avatar
pfogle
So did mine, it just wasn't going all the way to the "hot" side. Once we moved it there manually once it worked fine.
Old Nov 17, 2008 | 11:35 PM
mlcopen69's Avatar
mlcopen69
well i have 1 79 with the 351 m with new rad. new therostat, and new heater core mine will keep u from fezzeing to death but thats about it these old trucks never had great heaters
Old Nov 17, 2008 | 11:40 PM
fmc400's Avatar
fmc400
MSEE
Sounds like the heater core is gummed up, especially since that's the only thing you haven't serviced. When I flushed my system last winter, I back flushed the heater core and it was so full of crud that I'm surprised it let anything through it at all.
Old Nov 18, 2008 | 12:48 AM
alconk's Avatar
alconk
Huh.... time to replace it then.
Old Nov 18, 2008 | 02:27 AM
fmc400's Avatar
fmc400
MSEE
If it's not leaking, you don't need to replace it, probably just back flush it. When I back flushed mine (hooked up a garden hose and ran water flow the opposite direction), it looked like it literally took a giant number 2 out the other side, for lack of a better expression.
Old Nov 18, 2008 | 04:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When factory installed A/C is present, there's a heater water valve in the system, which is vacuum operated and notorious for rusting shut, or partially shut.
It splices into the heater hose, passenger side rear of the engine.
D4AZ18495A .. Heater Water Valve (Motorcraft YG136)
MSRP: $28.72 / FTEpartsguy.com price: $17.23
Old Nov 18, 2008 | 10:08 AM
73f100shortbed's Avatar
73f100shortbed
I agree with flushing the heater core. I'm surprised you had the box out and didn't do it honestly. They are cheap enough. But if you don't have a/c it is easy to take out again anyway
Old Nov 18, 2008 | 10:36 AM
alconk's Avatar
alconk
Well at the time I was on a budget, I know lame excuse yes I regret doing it then and no the truck does not have AC
