X died while driving
Old Nov 17, 2008 | 09:06 PM
FordTruckGirl77's Avatar
FordTruckGirl77
Yesterday I was out running errands and when I left one place I was backing out of a spot and the X just died while going backyards. It started right back up and I never felt it sputter. Tank is full. One time before it died right after I started it up then when I got home and shut it off it fired right back up when it was in the off position. Any ideas?
Old Nov 17, 2008 | 09:50 PM
Monsta's Avatar
Monsta
Sit. Stay.
It started with the key in the OFF position??
Sounds like, but may not be, a funky ignition switch or wiring associated with it. Very odd.
Old Nov 17, 2008 | 10:04 PM
FordTruckGirl77
Yes, the same day it stalled out in park when I got home and shut the ignition off to Aux only and it fired back up right away (by itself) and the RPM's were very high so I pulled the key out right away. Then nothing happened again till yesterday (about a month) and it died while in reverse.
Old Nov 17, 2008 | 10:18 PM
FordxFour's Avatar
FordxFour
I've never heard of this before either. By chance, you don't have remote start on it do you? (malfunction)...
Old Nov 17, 2008 | 10:22 PM
FordTruckGirl77
No I dont have the remote start, I dont even have an alarm.
Old Nov 17, 2008 | 10:23 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Might wanna get that checked out, remote start.....understandable; but for the truck to start itself like that? Something is definately wrong...
I'd start with the PCM...
Old Nov 20, 2008 | 12:51 PM
jayc3169's Avatar
jayc3169
Have you had any electronics put in. This happen to me in my 2003 Ford Expedition. I had a TV installed and the connected the power to the ignition by accident and everytime I turned the key to AUX or ON (not start just ON) it would start up by itself.
Old Nov 21, 2008 | 08:19 PM
jesterdog's Avatar
jesterdog
I have read threads on here before where wires were chafing in the steering column and causing crazy problems. Dangerous though. Some of them reported smoke! I would check there first.
