1995 Ford F350 4x4 7.5 460
1995 ford f350
Because i replaced the pass side head the machine shop said on the 95 7.5 you can swap heads side to side i spent a week putting the new head on ,it bolted up perfect,i started the truck it sucked all of the antifreeze into the oil almost instantly,never seen that happen before,i know i torqued the head right and double checked it,there is a obosious problem the machine shop assured me i could swap heads,but im guessing its not true because of the problem i now have,i dont think the ports are correct and that caused the antifreeze toleak into oil,i mean it leaked all three gallons within seconds,any ideas
I really need help with this problem,everyone i asked said you could put a drivers side head on the pass side and vice versa,is this not true ?as stated before machine shop said it could be done so i did it ,DO THE EXHAUST AND WATER PORTS LINE UP THE SAME WHEN YOU SWAP HEADS LIKE THAT?the truck has 50,000 miles on it
ryanparhaniemi
11-30-2016 11:07 AM
Kevin Thayer
17
01-23-2014 11:16 AM
