Help settle an argument
Old Nov 17, 2008 | 05:04 PM
mxfam's Avatar
mxfam
Hi folks, We have a truck in the shop that smokes white & stinks like fuel @ an idle.
The dispute is color of smoke I.E.
Does white, black,blue smoke mean oil or fuel, coolant?
What color means what?
lets get some opinions!!!
Old Nov 17, 2008 | 05:06 PM
F250_'s Avatar
F250_
EDIT: nevermind.
Old Nov 17, 2008 | 05:07 PM
nlemerise's Avatar
nlemerise
Fuel is white (at start up cold)...
Old Nov 17, 2008 | 05:11 PM
Action4478's Avatar
Action4478
My wag would be fuel ...(White)
Either the IPR is sticking or may need an EOT sensor ...
Old Nov 17, 2008 | 05:40 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Blue-grey usually means oil.
Old Nov 17, 2008 | 05:53 PM
F350-6's Avatar
F350-6
Borrowed from dieselmann's page
Smoke analysis
<dl><dt>White smoke: </dt><dd>Caused by unburned fuel passing through the engine. Some white smoke is normal on cold start-ups.
Excessive white smoke could be an indication of inoperative glow plugs, loose injectors, low compression from worn rings or bent connecting rods, or coolant leak into the cylinders--head gasket or injector well sleeves. </dd><dt>Black smoke: </dt><dd>Caused by excessive fuel for the amount of air drawn into the cylinders. Some black smoke on hard accel or at higher altitudes is normal.
Excessive black smoke could result from restricted intake or exhaust, inoperative leaking or weak turbo, intake hose(s) leaks, leaking or worn injectors, fuel return or supply restriction, stuck Exhaust backPressure Regulator valve or solenoid. Also PCM inputs such as BARO MAP ICP or EBP sensors. </dd><dt>Blue or blue/white smoke: </dt><dd>Caused by insufficient fuel or oil consumption. Normal when engine is cold or idling for extended periods.
Excessive smoke could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, worn or leaking injector o-rings, thermostat stuck open, oil consumption, or plugged crankcase depression regulator valve. Also PCM inputs such as MAP or ICP sensors.</dd></dl>
Old Nov 17, 2008 | 05:54 PM
F250_'s Avatar
F250_
Excellent, Chris. I'd give you some rep, but have to spread it around.
Old Nov 17, 2008 | 06:29 PM
Ponyboychris's Avatar
Ponyboychris
I have the same smoke analysis paragraph copied to my computer as well. Helps me keep this stuff straight.
