bleeding brakes
Old Nov 17, 2008 | 10:14 AM
brentleedragon's Avatar
brentleedragon
Oh yeah, I understand why its done off the truck.
Another couple places I wont mention my help was that the people told me to literally "bench" bleed it on the truck that it is the same thing as doing it on the bench. So I figured there was no difference based on what more than one person said "bench" bleeding on the truck.
Mislead information kinda sucks lol, but its not a big deal to take the MC off. Good thing you can set me straight haha
Old Nov 17, 2008 | 01:53 PM
73f100shortbed's Avatar
73f100shortbed
You should bench bleed it like everyone has recommended. If you really don't want to remove it you can crack open each line one at a time on the master cylinder and bleed it there too. Then do each wheel. I've had luck this way, but the right way is to bench bleed like everyone has suggested.
Old Nov 17, 2008 | 02:31 PM
Alvin in AZ's Avatar
Alvin in AZ
Ok, I never thought I needed to "bench bleed" until reading this thread. :)
So if the dumb master cylinder needs to be tilted forward or sideways...
then back the whole dangged pickup up a hill or something. LOL :)
But anyway...
Since after bleeding the brakes (the wrong way;) the pickup will eventually
get backed up a hill at some point, the trapped air will get let loose and so
maybe that's the reason for others saying bench bleeding ain't necessary?
My youngest son showed me this one, bleed them by yourself...
-keep the master cylinder full, watch it under the open hood
-slip a good fitting hose over the farthest bleeder screw, open only that one
-place the end of that hose down into a jar with a little bit of clean fluid in it
-pump the brake slow and easy
-when the brake fluid runs clean and no bubbles in the jar...
-close that one and go onto the next one
As easy as that.
Alvin in AZ
ps- don't forget to back up a hill and pump the brakes at some point? LOL :)
regidog
28
Nov 18, 2020 05:26 PM
TNLuke
Sep 12, 2011 10:23 AM
grostig
Aerostar
19
Jun 28, 2011 08:23 PM
BigSix1
Nov 24, 2004 09:59 AM
goose213
1978 - 1996 Big Bronco
Nov 22, 2004 03:12 AM
