Maintenance Shedule
Old Nov 24, 2008 | 12:48 PM
Brandon_01's Avatar
Brandon_01
Originally Posted by davez03navi
Squeeking??? I'm beting on it being the outer tie-rod ends..
Yeah, that's the best I know how to describe it. I'll see if I can get a sound clip for you guys. But there may be so much engine noise till you can't hear it.
Old Nov 24, 2008 | 12:52 PM
alwaysfords41's Avatar
alwaysfords41
Rear end grease? Do you have the LSD rear? Sounds to me like it is the rear diff clutch packs. It is over due for a drain and fill. Make sure you use the synthetic for LSD's and use the friction modifier. My dealer re-did the fluid change I did and added an extra bottle of modifier and it cleared up the grinding that a single bottle didn't.
Old Nov 24, 2008 | 12:56 PM
Brandon_01's Avatar
Brandon_01
Yeah, sorry....its the LSD rear.
Old Nov 24, 2008 | 12:59 PM
alwaysfords41
Fluid change will clear that up most likely. Should take around 20 minutes and cost about $80 in fluid.
Old Nov 24, 2008 | 01:01 PM
Brandon_01's Avatar
Brandon_01
That's what I was thinking, about $100 or less.
Old Nov 24, 2008 | 01:14 PM
alwaysfords41
Probably want to do the T-case and front diff too. T-case isn't hard, just hard to wiggle around and you need a fill tube to get the fluid back in. Front diff cover is annoying and the job is messy.
Old Nov 24, 2008 | 04:46 PM
johnpvb's Avatar
johnpvb
Could also be the idler arm bushing if if happens while turning the wheel...that happened to me about a year ago.
Old Nov 24, 2008 | 08:04 PM
High_Horse's Avatar
High_Horse
Idlers are known to go around 100k or so, that would be a good place to look. Plus they do creak a lot when worn.
