leaking diesel
Old Nov 16, 2008 | 09:46 AM
toddncandy's Avatar
toddncandy
leaking diesel
2000 F-250 leaking quit a bit of diesel when i start the truck, i changed the fuel filter and thats when it sarted, took the filter back off to check the gaskets and they were fine. any sugestions
Old Nov 16, 2008 | 09:57 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Look under the front passenger side of your engine. You will see a tube leading from the water seperator valve on the fuel bowl. These o-rings often go bad. Here is how to change these o-rings. click here.. If this is the problem.
Old Nov 16, 2008 | 10:02 AM
toddncandy's Avatar
toddncandy
thank you very much, will check that when i get home
Old Nov 16, 2008 | 10:27 AM
cangim's Avatar
cangim
If you drained the bowl first prior to changing the filter. It is likely that is where it is leaking from.
