Problems when engine cold
Old Nov 16, 2008 | 07:21 AM
armand037's Avatar
armand037
I have a 2004 Crew Cab 6 litre and idles rough and won't rev up when it is cold,any idea what is causing the ploblem , thanks Armand
Old Nov 16, 2008 | 07:38 AM
ponyboy123's Avatar
ponyboy123
I have a 2004 f 350 6.0 and it does the same thing. How does it start first thing in the morning? I need to get mine in to have the glow plugs checked and the bowl heater checked as well.
Old Nov 16, 2008 | 04:47 PM
armand037's Avatar
armand037
It will start ok but it won't rev up till it is warm, its almost like its not running on all cylinders
Old Nov 16, 2008 | 05:16 PM
Georgejg13's Avatar
Georgejg13
I had the same problem. Took it into the dealer and had it flashed with the heat induction flahs and all the problems went away. I even have a little more power now. Went out this morning, 22 degrees F. and it started right up and I drove away. Definatly the best thing I did for my stock truck
