Sponsored by: Real Truck
help - rough running v-10
Old Nov 15, 2008 | 08:55 PM
1cerberus4u's Avatar
1cerberus4u
Hey all:
99 250 with a v-10 auto 190K. The truck is great but always had a tendency to eat coils and exhaust studs. Now, primarily on the highway in Od (and just cruising, light on the throttle) the truck stumbles, like a bad coil. If I floor it, it goes away, so it's just at cruising speeds. I checked codes for a bad coil but it does not show any. changed the fuel filter and no luck.
My thoughts ar that maybe there is a tranny sensor that may be going bad??
Any thoughts?
Thanks
Andy
Old Nov 16, 2008 | 06:43 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Might want to try down in the V10 forum. Lots of guys there that will help out.
Sounds like another misfire.
Misfires in the Superduty don't usually throw a code. You need to read the misfire counters to find out which exact cylinder it is.
Old Nov 16, 2008 | 08:50 PM
rudedogii's Avatar
rudedogii
I heard some where that the early V10s had problems with the coil packs.
Old Nov 17, 2008 | 07:06 AM
1cerberus4u
Thanks guys. will do
