Chip Question
Old Nov 15, 2008 | 01:46 PM
benjibob25's Avatar
benjibob25
Chip Question
I bought a 2001 Ford F250 Superduty with the 7.3L in it about a month ago and the dealer I bought it from thought it had a banks chip in it. Well it it does im not impressed and want to put the bully dog 6 position chip and so I can smoke ****! Can anyone tell me how to go about figuring out what it has? Also it may sure have been programmed and if so would it mess anything up to put the chip in? Thanks Ben
Old Nov 15, 2008 | 01:53 PM
megawatt00's Avatar
megawatt00
Welcome to FTE Ben. Do you have guages in the truck? They are a must when running any type of chip or aftermarket programming. The most popular tuner here is DP-Tuner Im not to sure exactly how to tell if your PCM has been reflashed though. Others will chime in shortly.
Old Nov 15, 2008 | 02:12 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE. Without a lot of posting here read this, its on the 2nd page.
https://www.ford-trucks.com/forums/7...rogrammer.html
Old Nov 15, 2008 | 02:14 PM
mongo75's Avatar
mongo75
Just to make sure you heard it- go DP TUNER lol
Old Nov 15, 2008 | 02:36 PM
PwerStroke99's Avatar
PwerStroke99
Yea u definitely want to go with Dp-Tuner, forget about Bully Dog, Edgeand Banks. If u want want better power, Dp-Tuner is the way to go
Old Nov 15, 2008 | 06:10 PM
Steve_250's Avatar
Steve_250
Here is the other thread you started on the same thing.
https://www.ford-trucks.com/forums/7...-question.html
Old Nov 15, 2008 | 11:23 PM
jdecker88's Avatar
jdecker88
Get that banks crap out, keep the sticker though its good for 5 HP . Follow these links and get either a DP-Tuner or Tony Wildman tunes.
Old Nov 16, 2008 | 06:30 AM
That_Guy's Avatar
That_Guy
I think the Banks stuff reflashed the PCM and if thats the case you will have to get a scan tool.
Old Nov 16, 2008 | 11:29 AM
cangim's Avatar
cangim
I am almost postivie that if you add a chip like DP the "stock" will be what ever is on the PCM. So basically if the ECM is programmed by "Banks" your stock position would be the banks programming. That being said, I didn't think banks did any ECM flashing? I know they have the otto mind and six gun, but wasn't aware of anything to reprogram.
Old Nov 17, 2008 | 11:47 AM
aklim's Avatar
aklim
I think Banks is an expensive 10K mod and I don't think it touches the PCM programs.
Old Nov 17, 2008 | 11:56 AM
That_Guy's Avatar
That_Guy
Well I was wrong again. lol.
Old Nov 17, 2008 | 02:03 PM
HKusp's Avatar
HKusp
Has anyone mentioned getting gauges and a DP tuner yet? If not, that's the way to go....
Old Nov 17, 2008 | 02:53 PM
aklim's Avatar
aklim
I would think it is better to get gauges FIRST and run it for a couple of weeks so you know what the baseline is.
Old Nov 17, 2008 | 02:54 PM
87 F-150 I6's Avatar
87 F-150 I6
DP Tuner!
