Timing woes
Old Nov 16, 2008 | 07:54 PM
rhetor's Avatar
rhetor
is the vacuum line going to intake vacuum or carb vacuum?
Old Nov 16, 2008 | 07:59 PM
fzeed's Avatar
fzeed
The one i am referring to goes to the carb. There is one on the intake, but i was told to cap it off when installing the new carb.
Old Nov 16, 2008 | 08:05 PM
jwtimme's Avatar
jwtimme
Before I replaced my dizzy with an msd I just left the vaccume advance off, could not get the motor to stop pingging with it hooked up. But I ran electronic ignition, are you running points or breakerless ignition. I belive that the advance should be connected to manifold vaccume but if I'm wrong someone will let you know.
Old Nov 16, 2008 | 10:18 PM
fzeed's Avatar
fzeed
im running points.
Old Nov 17, 2008 | 06:40 PM
rhetor's Avatar
rhetor
here is a quick way to see whether the vacuum line is plugged into intake vacuum or venturi vacuum (the carb can have ports for both):
Unplug the line at the vacuum advance diaphragm while the engine is idling. Put your finger over the line. If you feel a strong suction with the engine at idle, that is manifold vacuum. If you feel no or very weak suction, that is venturi vacuum.
Venturi vacuum INCREASES when engine load increases.
Manifold vacuum DECREASES when engine load increases.
Here is my suggested coarse of action:
1) unplug and cap the vacuum line
2) set base timing to 10*
3) plug in the vacuum line and check the timing. if it goes up above 17*, leave it plugged in. If it doesn't move much, try switching to a different vacuum source.
Let me know what kind of vacuum you are plugged into and how much the vaccum advance increases the timing at idle when the vacuum line is plugged in.
A proper working vacuum advance should:
-Allow for low base timing for easy cranking and cold engine start.
-Increase low to mid rpm throttle response
-Increase fuel mileage and better emissions.
Old Nov 17, 2008 | 07:46 PM
BobbyFord's Avatar
BobbyFord
Throw your point dist in the trash and get a re-curved Duraspark dist. from Scotty Johnston in Tacoma ( Re-In-"Car"-nation High Performance and Automotive Repair/index )
Also, remember that your 1973 timing set is retarding the camshaft several degrees. A pre-'72 timing chain set is what you want to get your camshaft back where it belongs.
Call Scotty and he will hook you up with a distributor that will work with your specific combination. He is VERY knowledgable on Ford 460's.
Old Nov 18, 2008 | 11:25 AM
Danger_Dave's Avatar
Danger_Dave
wish i knew about that ^^
i paid 500 bucks for a performance distributors dui setup
Old Nov 18, 2008 | 12:26 PM
Freightrain's Avatar
Freightrain
Originally Posted by Danger_Dave
i paid 500 bucks
I'd throw a Pertronix in a stocker before paying any kind of big bucks for a dizzy. To each their own, but I'm not spending that kinda money on a dizzy.
Old Nov 18, 2008 | 02:57 PM
Danger_Dave
yeah its a badass distributor. i just wouldnt recommend the wires to anybody. they sell special wires that are made by a different company and fall apart and are garbage. i'm gonna get some taylormade ones and then send back these piece of crap livewires to them and tell them i would appreciate a replacement set, and if they say no then they can keep their garbage because garbage doesnt belong in my truck, and i will tell everyone else they are garbage as well.
Old Nov 18, 2008 | 04:45 PM
fzeed's Avatar
fzeed
when i check the vacuum, it has strong suction
