no 4 low
Old Nov 14, 2008 | 04:37 PM
joslawn33's Avatar
joslawn33
no 4 low
Back in the summer ran into a smart @$$ bout his dodge rumble bee how his truck could pull mine well I was drinking so I put the 86 F250 4x4 on him. Put the truck in 4 low pulled him dn the road, smoke was roling any ways it went into 2 high no probs and goes in 4 high no probs but the shift will not go in 4 low. What could of happened? any feed back appreciated.
Old Nov 14, 2008 | 05:06 PM
86F250BIGBLOCK's Avatar
86F250BIGBLOCK
do you have the transmission in neutral when shifting in to 4 low? Did you initially get it into 4 low?
Old Nov 14, 2008 | 06:04 PM
ri_truck_guy's Avatar
ri_truck_guy
Check the shifter bushings...they sometimes just go bad and don't allow full range of the shifter.
Old Nov 15, 2008 | 07:38 AM
joslawn33's Avatar
joslawn33
Yea the shifter went in 4 low fine & went out fine just wont go back in 4 low. Thanks for the replys.
Old Nov 15, 2008 | 11:09 AM
cbrcassio's Avatar
cbrcassio
If you put the truck into any kid of bind while it was in low range you could have bent the linkage or bound it up. I'd check that and your bushings for failure.
