Looking for following Motorcraft part numbers for the 1965-75 I6 300.
Ignition Coil
Oil Filter
Fuel Filter
PCV Valve
Temperature Sender
Oil Pressure Sender
Ignition Coil DG5 / 1975 = Are you converting to electronic ignition?
If not this is the only coil needed, it fits all 1956/75's without electronic ignition. __________________________________________________ _________
Oil Filter FL1A
Fuel Filter
PCV Valve EV50
Temperature Sender: 1965/66: SW344 / 1972/85: SW925
Oil Pressure Sender
Thanks
Oil pressure sender: Do you have a gauge or a light?
Where is the fuel filter, inside the pump? Screwed into the carb? Or someplace else?
